backup failed from original tivo series 2 to another tivo series 2 hard drive
  • backup failed from original tivo series 2 to another tivo series 2 hard drive
    I had loss of power failure during tivo software update on my 1st tivo. So took out original drive ( failed update during power failure ) and with instacake , installed 250 gb new drive and tivo works fine. (call tivo X)
    I just got series 2 tivo with first 3 digits service no being same with tivo x. (call it tivo Y)
    What I want to do: Restore my failed original drive (from tivo x)
    Now With upgrade insutructions for restoring one original drive to another original drive ( both original drive has same capacity),from http://tivo.upgrade-instructions.com/step4.php
    "TiVo Replace Upgrade Instructions for your 540040:"
    I did everything as mentioned.
    put working original drive as primarry master ( from tivo y)
    put failed upgarde drive as secondary salve ( from tivo x )
    boot up with MFStools 2.0
    and use command with appropriate modifications
    :mfsbackup -f 9999 -so - /dev/hda | mfsrestore -s 127 -r 4 -xzpi - /dev/hdd
    and I get this..
    /devhdd: no such file or directory 09%
    restore failed: unable to open destination device for writing
    Can anyone help. ?
    I assumes that Original drive(from tivo X) do not work due to corrupt tivo software (power failure during tivo software update) and I can salvage that with trasfering tivo software from original drive from tivo y
    Generally if the original drive failed, the error would point there, but that still may be the case. Have you tried testing the /dev/hda drive?
      Orignila drive from new tivo- hda ( Tivo Y) shows 40 gb capacity and original drive from old tivo - hdz (tivo X - corrupted original drive) also shows 40 gb capacity.. I am tryint to attach screen shot from the computer screen
      kapadia
        sombody please help
        can someone look at the screen shot that i attached with previous message and help me.
        thanks in advance
