Does anyone know if the new HD tivo have multi room viewing??
does new HD tivo have multi room viewing??
I've got a 100Mb wired connection being pulled to my Series 3 in anticipation of the forthcoming good tidings in Nov. My DRT400 is already too slow at 54Mb, so I'm hoping the wired connection will help. If I could figure out a way to get Gb ethernet on the Series 3, then I'd really be a happy man!
If I have a Series 3, am I better off getting another Series 3 when MRV comes out in November, or will the HD units be fine? Doesn't look like much advantage to Series 3 over the HD. I have a wired gigabit network, but I guess I'll only get 100mb out of it.
Sounds good. Any reason to choose one over the other? Do the remotes use the same coding, because that may cause a potential problem. I have a Harmony Remote 890 (?). If I press a button in one room, is it going to be working on both TiVos? If so, how does one solve this problem?
I know I should wait for the feature to be released, but do you think I can assume if I'm picking up OTA HD programming, there should be no issues in transfer?
James
The remotes do use the same codes, but you can set them (and your Harmony) to use different codes for each unit. More info is here:
http://customersupport.tivo.com/Laun...b-8abbe082577d
We do think OTA HD content will be movable.
As far as choosing one over the other, see our TiVo HD and Series3 comparison.Been here a long time . . .
Originally posted by WK-Jeff View PostIt is available now!
But I can order the Series 3 from Amazon, and buy the 750GB upgrade from WK for $399 and I end up saving $208 + I get to keep my original 30 hour drive. The only drawback is I can't get the extended warranty.
Since it's 2am here I can't call now, but will call tomorrow to discuss options, and confirm availability of MRV and multiservice discounts with my current lifetime subscription Series 3.
JamesLast edited by jasel; 11-06-2007, 10:54 PM.
