1st Series2 upgrade - is HD capacity right?
    After you restore the image onto the new drive and put it into the other TiVo, you do the C&D in the TiVo...so once the drive is in it's final home, do the C&D in that TiVo. You are going to lose all of the recordings; that is how the process has to work.
      Thanks, I'll give this another shot......once my 40hr tivo A drive is restored, can i try to 'expand' it again. The drive i'm using to make a restore image from is an 80hr tivo and has never been expanded
        OK - so just to be clear, the 80 GB image will only fit on a drive that size or larger. You can't put the 80 GB image on a 40 GB drive, because the partitions (even unexpanded) are already too large.
          No problem. I was planning to rebuild my 40hr tivo with a 160gb drive; the old 40gb drive is a bit noisy now and smaller size EIDE hard drives are hard to find at your local retailer these days. Once this drive (or any drive, really) is restored using a pre-expanded image, can I restore back to this image and try to expand again if my next attempt fails? (or really, if i mess up again!)
          thanks.
          • #20
            Yes - any time you make an image file, you shrink back to the original size that came in that unit, and you can re-expand from there.
            • #21
              Well, I retried this all over on my 2nd 80hr tivo with fingers crossed and all went well. I made a backup of the original tivo A drive (which appeared to go ok), added a western digital 500gb for a new tivo B drive, and it now reflects about 650hrs of recording time with all programs and preferences intact. Thanks for all your help!!
              How can i verify if the backup image is good or even there? When I tried the backup process, it stated 'successful' with the source and the image being 80hrs. But when i try to restore this image to a new 160gb drive, with the following command:
              mfsrestore -r 4 -s 127 -bzpi /mnt/dos/tivo.bak /dev/hda
              i get the following error
              /mnt/dos/tivo.bak: No such file or directory
              here's the drive setup:
              primary master - new tivo a
              primary slave - windows c: with recovery/backup
              secondary master - dvd rom
              secondary slave - cdrw
              any suggestions?
              *i've already lost all the programming on this one & i'm close to sending it in but i'm stubborn; i'm sure i get this one running!!
              • #22
                Had you mounted the C: drive before running that command?
                • #23
                  I tried the mount command:
                  mount /dev/hdb1 /mnt/dos
                  with the following error:
                  /dev/hdb1/: Invalid argument
                  mount: mount point /mnt/dos does not exist
                  was I supposed to enter both lines:
                  mkdir /mnt/dos
                  • #24
                    Yes, first you have to make the directory /mnt/dos using "mkdir /mnt/dos"
                    Then you can mount the directory.
                    • #25
                      When I enter the 2nd line - 'mount /dev/hdb1 /mnt/dos' - I get the following error:
                      /dev/hdb1: Invalid argument
                      FAT: unable to read boot sector
                      mount: you must specify the filesystem type
                      along with way too many lines of the following to retype:
                      hdbb1: bad access: block =0
                      end request: I/O error...............
                      any advice? thanks!!
                      • #26
                        Just an update:
                        after a jumper adjustment and several attempts, all was resolved. Much thanks for all your help; my tivos now have a combined recording capacity of over 1400 hours!! Outstanding!!! (no more recording at horrible 'basic' quality!)
                        thanks again for your help
                        • #27
                          OK - that's great. It sounded like you had a bad drive in there, but if it's working now, wonderful.
