Copying drives
  • Copying drives
    According to one post, the speed of the copying can be greatly increased by enabling 32-bit I/O and DMA on the IDE drives, by issuing the command: hdparm -c1 -d1 /dev/hdx, for each drive.
    If you use the "dd if=/dev/hdx of=/dev/hdx bs=1024" command how would you add the hdparm command?
    Just run hdparm command(s) before the dd. It just changes a setting.
      Do I issue the command for the Tivo original and the duplicate or just one time for both drives before the dd command on a separate line before the dd? Like:
      hdparm -c1 -d1 /dev/hdc
      hdparm -c1 -d1 /dev/hda
      (This assumes the Tivo original is secondary master and dupicate is a primary master)
