Please, Need help with new Upgrade Replacement Kit
  • Please, Need help with new Upgrade Replacement Kit
    I ordered an upgrade replacement kit with 320 GB harddrive to get more hours on my Directv Philips Series 2 (40 GB) DSR7000. New harddrive and adapter installed today, but it is stuck on the grey "powering up" screen. The old harddrive was working fine, I just wanted more hours. What can I do now? Would appreciate any help.
    Hi. I had a similar problem with doing a hard drive upgrade recently. I went from a 160GB to a 1TB drive. The drive was a SATA drive and required an IDE to SATA interface card.
    I installed everything as directed and ended up with the same problem as you described. Long story short I had WeaKnees send out another kit and found out that there was a problem with the first interface card. I installed the replacement card and everything is fine now.
    Hope that helps.
      Try just uninstalling and reinstalling the parts. You likely just have a loose connection in there somewhere.
        Thanks for your responses. You were right W-K Michael. It must have been just a loose connection. My new harddrive came with an adapter that I must not have plugged in tight enough. It seems to be workin fine now. Again, thanks for your help.
