Results 1 to 3 of 3
Thread: SWM-LNB Wiring
    May 2009
    Default SWM-LNB Wiring
    Can I install a splitter between the Dish and the Power Inserter on a SWM-LNB? I want to be able to split the signal wire on the roof near the dish and send the signal to two apartments. I know that a SWM-8 will work, but I would prefer to use a SWM-LNB. I have tried searching and checked the wiring diagrams but did not see anything that matched.
    Thanks in advance.
    2,812
    Yes, just be sure the power inserter is connected to the power-passing port on the splitter.
    Jun 2009
    12
    you can also stack two four splitter one for each appartment if you wanted too.
