Bad Checksum
  • Bad Checksum
    I upgraded my Series 3 TCD652160 with preformatted WD 1 TB drive I got off of ebay. I tried to backup the new drive using the weaknees and hinsdale info in case of future need. I have a FAT32 partition formatted backup drive on a PC. I loaded the Weaknees CD with SATA.
    mkdir /mnt/dos
    File exists
    mount /dev/hda1 /mnt/dos
    was accepted
    mfsbackup -f 9999 -6so /mnt/dos/tivo.bak /dev/hda /dev/sda
    resulted in:
    Primary volume header corrupt, trying backup.
    Secondary volume header corrupt, giving up.
    mfs_load_volume_header: Bad checksum.
    I tried the same procedure on the drive I removed from the TiVo with the same result. I installed the new drive and went though the TiVo welcome process and it works fine.
    Any help would be appreciated.
    Regards,
    Mike
    "/dev/hda /dev/sda" is your problem. Why do you have two drives as your backup source--one IDE and one SATA?
      Sorry - I was in error
      Jeff,
      I must apologize. I actually did not type:
      I actually typed
      mfsbackup -f 9999 -6so /mnt/dos/tivo.bak /dev/sda
      and received the error.
      I just tried again with the same results.
      Mike
        Sounds like your original drive is bad. Does it still boot?
          Yes Jeff, they both boot up in the TiVo.
          I cannot backup either of them.
          Mike
          PS: I apologize for the delay in replying; the forum does not send out an email when you reply even though I subscribed.
            OK - I'll look into the email problem.
            I just realized the problem, though. These tools work for all TiVo models except the TiVo HD and the TiVo HD XL. Sorry.
              Ah ha - darned.
              Is there any way to backup Tivo HD that you know of?
              Any lead would be appreciated.
              Mike
                We use our own internal tools here - sorry.
