Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Jitter, stutter, and Pixelation
  1. #11
    6,880
    I really don't have a good guess here. Those results with the UPS are very strange. Maybe it's defective, despite the lamp test? A lamp isn't really sensitive to the steadiness of the power, like an IC.
  2. #12
    Jan 2012
    6
    Question Problems
    Well I installed the 1T drive and lots of stutter and Pixilation. I did not notice a fix that worked so????
  3. #13
    6,880
    What are you plugged into? Where are you? What model cable box do you have? How old is it?
  4. #14
    Jun 2011
    6
    Default A brand new UPS solved my stutttering issue, however ...
    Quote Originally Posted by VVitug View Post
    Same problem here. Got a 1tb expansion drive (Order #853376) and attached it to a Time Warner Scientific Atlanta 8300HDC running Mysto. The stuttering is just so irritating.
    Will a UPS clear up the issue? Should both the DVR and the expansion drive be on the UPS?
    Just ordered a UPS, hoping that it will fix it.
    The brand new UPS solved it beautifully and it worked perfectly since then. I plugged in both the DVR and the expansion unit into the new UPS.
    Sorry I was not able to post an update.
    Today, however, I changed over from Time-Warner to Verizon Fios and my DVR is now a Motorola 7232. Could I use my 328E S-u2eS expansion drive on the Motorola?
    The specs on the Fios website state that the Motorola can use a Western Digital WDBACS0010HBK-NEV2. The drive on my expansion unit is a WD10EURS. Can I just plug it in?
    If it will not work on the Motorola, what can I use it for? Hate to waste a good 1 tb drive.
  5. #15
    2,829
    The following FiOS TV DVRs are compatible with the weaKnees external, from what we understand:
    Motorola QIP 7216
    Motorola QIP 7232
    Cisco CHS 435 HDC
  6. #16
    Jun 2011
    6
    Will try it over the weekend and let you know. Thanks,
  7. #17
    Jun 2011
    6
    Unable to test if the 1 tb 28E S-u2eS expansion drive works. Power supply was dead. Tried to find a replacement from tne weaknees website and could not find it. Is it available and, if so, how can I order it.
  8. #18
    6,880
    Please email us at info@weaknees.com and we can send you special order instructions for that part.
  9. #19
    Oct 2013
    5
    I just installed 1TB expander to my SA 8300. Installed perfectly. Only problem is this pixilation freeze thing others are commenting on. It's not too prominent, but still a little annoying. What are the ideas for fixing this? Thanks.
  10. #20
    2,829
    Quote Originally Posted by Dave Laz View Post
    What model drive do you have? From us?
