Results 1 to 7 of 7
Thread: Upgraded HD and now have connection issue
  1. #1
    Join Date
    Apr 2011
    Posts
    3
    Question Upgraded HD and now have connection issue
    I installed a single HD upgrade and now I can not connect to my local network and complete the guided setup.
    The Tivo can see my network SSID and prompts for my password. Then after a few minutes I receive a "could not connect to wireless network "abc" (N06)
    I have tried changing the SSID. Changing the password/network key. Removing the password, etc. and receive the same error each time.
    I have tried using the phone line and the Tivo states there is not a dial tone. However, I think this might be due to using a VOIP service.
    Any ideas or help would be much appreciated.
    Thank you,
    Brent
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,877
    Default
    What exact Wifi adapter are you using? What model TiVo is it?
  3. #3
    Join Date
    Apr 2011
    Posts
    3
    Default
    Tivo is a TCD24004A the wireless adapter is a D-Link DWL-122.
    I have picked up a Tivo wireless G adapter at Best Buy. I will try it later tonight and see if it works. I'm hoping it's a firmware issue and for whatever reason the new drive does not like my D-Link adapter.
  4. #4
    Join Date
    Apr 2011
    Posts
    3
    Default
    The Tivo adapter did the trick (with a little hand holding). I removed the D-Link adapter and plugged in the Tivo adapter then restarted the system (unplugged it and plugged it back in).
    The Tivo adapter did not see any SSID that the D-Link could show. However, I manually setup the Tivo with my SSID and password/network key and it connected! (:
  5. #5
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,877
    Default
    Yup - TiVos can be really finicky with anything but the TiVo brand adapters. And the newer TiVos will ONLY work with the newer adapters.
  6. #6
    Join Date
    Sep 2011
    Posts
    1
    Default
    Replaced hard drive. TV screen shows "welcome powering up".
    Nothing happens.
  7. #7
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,877
    Default
    Quote Originally Posted by hlsolo@hotmail.com View Post
    Nothing happens.
    Did you properly format the drive with the OS for your exact model TiVo?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
