Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: No VOD or Netflix
    Mar 2015
    12
    Default No VOD or Netflix
    Hello,
    I just replaced a failed hard drive in my TiVo Series 3 with a 1TB drive sold by Weaknees.
    I connected the drive myself and everything is working fine as far as network access go. It's connected by wired Ethernet to a LinkSys WRT54GS router and then to a Comcast cable modem. At this time the network settings have been configured to use the network instead of the phone to connect to the TiVo service. Either way has worked - connection status is always "succeeded".
    The problem I have is that I can't access Video On Demand from the TiVo Central menu. If I click on the option, it just returns to the main menu.
    Also, there is a Netflix icon in the Now Playing list. This behaves the same way. If I click on it, it just returned to the Now Playing menu.
    I called TiVo about this and they ran me through a few troubleshooting steps to verify network connectivity. They also verified that my privacy setting for streaming media was set to "Opt-In".
    The software version is 11.0K-01-2-648. TiVo says this is the latest version. I saw an earlier post in which the user was advised that a software upgrade would fix the problem. Unfortunately since I have the latest, I'll have to do something else to make this work.
    Any ideas what's going wrong?
    Thanks for your time,
    Alan Mintaka
    6,879
    How long has the drive been in the unit? It may take several hours to finish indexing your data and to make all services available.
    If it's been more than 24 hours, then you should try a restart.
    Mar 2015
    12
    Hi Michael,
    Thanks for the fast response. The drive has been in the unit about a week. I've been going back and forth with other things and TiVo to try and get something working.
    I tried a reset from the settings menu but the results are the same. Video on Demand (Tivo Central Menu) and Netflix (Now Playing list) just return to the same menu.
    Since my first post, I also tried disabling the firewalls in my router and cable modem. That made no difference either.
    BTW this is the second third party drive that has failed with the same symptoms. The first was bought from an eBay seller who made the same plug-and-play claims that Weaknees does. He wasn't able to diagnose the problem via email and essentially gave up.
    I'm open to suggestion at this point. Should I send the Series 3 to you guys for repair?
    Thanks again,
    Alan Mintaka
    6,879
    It feels like there's something about the networking going on here, since both of those features depend on broadband.
    Are you using wired or wireless?
    Have you tried it attached via ethernet directly to the cable modem?
    Mar 2015
    12
    From my first post, "It's connected by wired Ethernet to a LinkSys WRT54GS router and then to a Comcast cable modem."
    I have to get a M-M ethernet adapter and another cable to bypass the router. I'm working on that now.
    In the meantime, I did try a few other things:
    1. Disabled the firewalls in the router and cable modem. This made no difference.
    2. I remembered that once when I had a working Netflix interface, I was also using one of those TiVo USB-Wireless adapters. So I switched back to a wireless connection to see what would happen. That made no difference either, but at least it ruled out some kind of flaky difference between wired and wireless settings with this router.
    I should be able to by pass the router tomorrow. However I've been wondering about something else while I try to solve this intractible problem: could HDCP be running some kind of interference here? I'm not using the HDMI output on the Series 3. I'm using both the component video/audio and composite video/audio outputs (the latter for a "legacy" TV).
    I've seen HDCP blocking interfering with combinations of HDMI/component/composite video in the past. This is a stretch, I know, but I'm grasping at straws at the moment.
    Also, I'm short a few HDMI cables I'd need to see if that was the problem.
    Thanks for your continued time and patience. I'll post again when I've bypassed the router and tested the result.
    Alan Mintaka
    6,879
    Yeah - I've also seen strangeness related to HDCP. I also don't see how it fits in here, but considering past experience, I'd say it's possible. It's a good area to investigate.
    When you say "a few" HDMI cables, does that mean you have a matrix switch or a receiver in the mix? Those often mess with HDCP even more, so I'd take that out of the equation also, as a troubleshooting step.
    Mar 2015
    12
    Hello Michael,
    Long story short - nothing worked. I removed everything from the equation but a direct wired ethernet connection from the Series 3 to the Comcast Modem. I removed all A/V outputs from the Series 3 except HDMI. There were no switches or distribution amps of any kind in the mix.
    I also disabled all customizations in the modem, including the firewall and "port forwarding" (DirecTV advised me to add some ports to the list in order to run their PC application - didn't work, of course).
    I reset the both the modem and the Series 3 between each change. Also verified that the Series 3 could connect to the TiVo service as long as the modem was connected - no problems there.
    The only thing left I haven't tried is resetting the Comcast modem to factory defaults. However I have to talk to Comcast about that first in order to restore my ISP login correctly. I may or may not do that tomorrow.
    At the moment, my inclination is to remove the Weaknees hard drive from the series 3, return the hard drive for a refund, and toss this completely useless Series 3 in the dump. That's $1000.00 for the unit and $700+ for the "TiVo lifetime service subscription". Worthless if anything goes wrong.
    A hard lesson learned.
    Thanks for your time and patience while I figured out how badly I've been screwed by TiVo. Too bad I'm a slow leaner, eh?
    6,879
    Here's another long-shot thought: we've seen CableCARD problems that are actually related to a bad power supply, and bad power supplies are pretty common in your model these days.
    There's a pretty easy visual way to check for a bad power supply in the TCD648250B: bursting capacitors.
    See this page for more info:
    http://www.weaknees.com/bps
  9. #9
    Mar 2015
    12
    Hi Michael,
    Now that you mention it, I've heard of that one before in connection with the old Comcast cablecards I once had. That'll take a little downtime while I get the unit out of the component chassis and taken apart. I'll post as soon as I have a result.
    I also have yet to reset the modem to factory defaults. One thing at a time.
    Thanks again for hanging in there,
    Alan Mintaka
  10. #10
    Mar 2015
    12
    Hi Michael,
    Alan Mintaka
