Results 1 to 4 of 4
Thread: reconfirm DTV setup
    Apr 2015
    Default reconfirm DTV setup
    I am installing a set of DTV equipment into my Fifth wheel. there are 3 outlets. HR24, and 2-H25's total or 4 concurrent receivers 2+1+1 if all are active at once (unlikely)
    SWM with tripod mounted slimline dish, with SL-3 head. (one wire)
    I have had a single box (H24) at each port so the connectivity is right.
    anything that stands out?
    Sam
    6,698
    That looks right. I haven't used a SWM13 yet, but you certainly don't even need one in this situation. But it should work as well as a SWM8LNB.
    Apr 2015
    I meant to post that in the drawing the orange and gray wires are the ones supplied by the RV manufacturer.
    I corrected my post, it is actually an SL3, which supports 8 receivers.
    6,698
    OK - then it all looks good!
