Results 1 to 4 of 4
Thread: simple swm system question
  1. #1
    Join Date
    Apr 2017
    Posts
    2
    Default simple swm system question
    I have a Directv system with a sl3 lnb (sl3s4r5-01) and a H24-100 receiver that I want to connect to one tv. My question is do I have to use a power inserter (PI-21) and a splitter for this system to work and if so how should it be wired.
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,854
    Default
    You don't need a splitter with one receiver, but you do need a power inserter there - 21 volt.
  3. #3
    Join Date
    Apr 2017
    Posts
    2
    Default
    Thanks for your reply
    I have a few questions before I try to setup my new dish.
    My current setup is a 4 wire lnb with the dish mount to my roof running to one h24-100 receiver with a b-band converter.
    My new setup in a dish mount on a pole at ground level with a single wire lnb (sl3 s4r5-01) and I have a PI-21 power inserter.
    My questions are do I need to use the B-band converter and do I need to make any changes to my receiver settings?
    Thanks for your help.
  4. #4
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    2,826
    Default
    no, you remove the b-band converter.
    you will likely have to repeat satellite setup when you change the dish to a swm dish.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
