Results 1 to 2 of 2
Thread: New Recording not recorder - Power Loss
    Jun 2017
    Default New Recording not recorder - Power Loss
    I Have a TiVo Roamio OTA Series5 HD DVR for Antenna (ONLY!) Receiver. About every day now, for about 4 to 6 hours in the evening and night it is not recording the scheduled TV shows. It gives the message "Loss Power" I know the power is not loss because I have a computer plugged into the same outlet, that has 6 turners (NPVR) and it is set to record the same channels, which it does with no problem. Both of these units, the 1500 watt UPS. I just ordered a power supply for the Roamio OTA from you, to try and see if it is this. Do you have any other suggestions?
    2,813
    I'd suggest you set up a 24 hour manual recording, every day, and see whether the power loss is happening at the same time each day. If so, maybe you can watch to see what is happening on that day. It seems a bit odd and I'm not sure it's the TiVo. You might also want to bypass the UPS as a test.
Tags for this Thread
