Results 1 to 5 of 5
Thread: External storage question
  1. #1
    Join Date
    Jun 2017
    Posts
    1
    Default External storage question
    My TIVO 4 stopped working so I replaced the hard drive with one I got from weaKnees. TIVO works now, I had an WD external storage device on it with tons of taped programming. It says that it is unrecognized. If I add it, it seems that will erase all content. Any way to add it back without losing content?
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    2,831
    Default
    Unfortunately, no, there is no way to add the external and keep the content. The two drives in a TiVo are a married pair and when you separate them, all content recorded after the external was added is lost.
  3. #3
    Join Date
    Sep 2007
    Posts
    5
    Default
    IMHO, TiVo should add the ability to mount/unmount an external drive.
    I have a drive with a un-bootable OS and I'm installing a newly purchased Weaknees drive. Mounting an external drive should be smart enough to _attempt_ to scan the external drive for previously recorded shows that happen to be coherent.
    Do you think it will ever happen?
  4. #4
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,883
    Default
    Nope. Shows aren't specifically on one drive or another - most are written across both. So there's very little chance that you have a show that is fully on that external drive anyway.
  5. #5
    Join Date
    Jan 2020
    Location
    Louisiana
    Posts
    1
    Default
    Years ago I had one of the Tivo branded external drives attached to a premier that went bad after just over a year of use. Even though the external drive was only half of my total storage, I lost 95% of my shows. Tivo fragments the shows across the two drives. I was not happy!!
    Using an external drive only doubles your odds of losing everything if either drive fails....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
