Need to replace dying TiVo HD drive.
  • Need to replace dying TiVo HD drive.
    The drive on my TiVo HD is dying - emitting a high pitched noise as it goes.
    If I replace it with a blank drive, will the TiVo HD set up the drive?
    I would do the whole transfer thing, but I no longer have access to a PC - having long gone over to a MacBook.
    Any advice would be greatly appreciated.
    You would need a TiVo hard drive that is preprogrammed with the TiVo software. Find your TiVoHD model here:
    TiVo Hard Drives
    A blank drive won't work.
    You should also check to confirm that the noise is not a fan, which you can do by inserting a toothpick into the fan grate to stop the fan before you plug in the TiVo. Then remove the toothpick and see if that causes the noise to start.
