Results 1 to 8 of 8
Thread: that darn no cable provider
    Apr 2018
    4
    Default that darn no cable provider
    hi
    I have seen the posts here about the no cable provider found, but none of the fixes offered worked.
    I have a premier , It had sat unused for a couple years, and just before it sat unused I put in a new hard drive.
    well I go to use it now and that no cable provider found . I have been through it all with TiVo and there conclusion is
    that its a software problem. I haved tried every reboot and kickstarter code , even took it to a friends house and no luck.
    I don't want to give up on it as it has the lifetime service. anyone have anymore ideas ?
    thanks so much
    eddie
    6,842
    Have you tried 00000 as the zip code?
    That might get it past setup and to the point where it can download the latest OS, which might fix the problem.
    Apr 2018
    4
    hi
    I haved tried the 00000 and even tried 99999 zipcodes, even tried Canada zipcodes under Canada setup.
    whwn you get to the cable card section and you test the channels they are all there, but when you get the zipcode section
    you end up with that no cable provider found. as I understand it , it is/was a TiVo update that caused this? even TiVo support
    told me they had the problem but that they had it fixed.
    thank you WK
    6,842
    Well, you might need to just get a newer OS on your drive.
    Do you know what you have? You can press Info on the remote on the first screen once the unit boots, and it should report your OS version.
    Apr 2018
    4
    hi mk
    I looked and the os is 220.5.2.01.2.746 , does that mean a new hard drive ,which this one is , but was never used, or can it get loaded
    thank you
    eddie
    6,842
    Maybe 20.5.2?
    We are currently using 20.7.x.
    Does your 15-digit service number definitely start with 746?
    Apr 2018
    4
    hi wk
    the starting numbers are 746.
    thank you
    eddie
    6,842
    Then you may just need a newer OS - I can't guarantee it, but it's my best guess at this point.
    See this page:
    https://www.weaknees.com/misc.php
