Results 1 to 4 of 4
Thread: what dish and lnb do i need for a directv self install swm system
  1. #1
    Join Date
    Nov 2017
    Posts
    2
    Default what dish and lnb do i need for a directv self install swm system
    hi,
    i want to do a self install dish and lnb at a second home in the mountain. i will be using either a hr44 genie or a hr24 dvr. will only have 3-4 tv's at most
    i have spent time looking and cant figure out which dish and lnb i should get.
    can someone please help me? doing the install will be easy compared to figuring out what equipment i need.
    thanks
    tom
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,880
    Default
    You should get either a SWM3 or SWM5 LNB dish. The 5 is used in more rural areas, the 3 is sufficient for most major metro areas.
    Given that this house is in the mountains, you'll likely need a 5.
    These are a bit tricky to aim. If you have problems after installation, see if you can pay a local DTV person to just aim your already-mounted dish.
  3. #3
    Join Date
    Nov 2017
    Posts
    2
    Default
    nearest installer is a long ways aways and wants quite a bit. does the 5lnb use any directv slimline dish?
    any recommendations on installation equipment for aiming?
    thanks
    tom
  4. #4
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,880
    Default
    The dish is here:
    https://www.weaknees.com/cart/5-LNB-...ECTV-Dish.html
    For aiming, we really don't have experience with meters, but they cost quite a bit - more than your local guide, I'd bet.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
