Results 1 to 8 of 8
Thread: Tivo Bolt - Not booting and blank screen
  1. #1
    Join Date
    Oct 2018
    Posts
    4
    Default Tivo Bolt - Not booting and blank screen
    I bought a used 500GB Tivo Bolt when plugged in the red lights comes on for 1 second then then goes off. After that nothing else happens. I can hear the fan spinning and the hard drive spin up. I also tried plugging in a network cable to see if the Tivo gets an IP address but it does not. My thinking is that the boot ROM may be corrupt.
    • Is there a way to verify this?
    • If the boot ROM is corrupt, can it be re-flashed?
    • Could something else be wrong?
    Any assistance would be greatly appreciated.
    Thank in advance
    Andy
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,834
    Default
    I've never seen corrupt boot ROM on a TiVo. Ever. I really doubt it's that.
    That sounds like a bad drive. We have replacements here:
    https://www.weaknees.com/bolt.php
  3. #3
    Join Date
    Oct 2018
    Posts
    4
    Default
    Thanks WK-Michael...I have a drive that I can try. I will change it out and see if that works.
  4. #4
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,834
    Default
    What drive did you use?
  5. #5
    Join Date
    Oct 2018
    Posts
    4
    Default
    I had a WD 1TB drive laying around. I bought another used Bolt and put that same 1TB drive in it and it works fine so I know the drive is OK. The bad Bolt is acting like it isn't booting. Just a 1/2 second flash of red light and then nothing else. The fan runs and that is all I can tell. I would really like to get the bad Bolt back to a good state if possible.
    Thanks for your help.
  6. #6
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,834
    Default
    OK - I can't really say that's the definitive test of a drive working, but in any event, if you have another Bolt, have you tried the power supply from that other Bolt on the bad one?
  7. #7
    Join Date
    Oct 2018
    Posts
    4
    Default
    Quote Originally Posted by WK-Michael View Post
    Yes I tried a PS from a good Bolt. Didn't help. I also tried the original 500GB drive from the working Bolt I have. It still did not help. So I think I can safely say it is not the drive in this bad one. I just don't know what else could cause this. Since you are able to put a blank drive in the bolt and boot it, I assumed the TiVo OS is on a ROM chip on the motherboard. My first hunch was that ROM is corrupt and needs to be re-flashed since this unit does not boot.
  8. #8
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,834
    Default
    Sounds like it must be a bad motherboard. We've only seen a couple of those on Bolts, but that sure is all that's left.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
