Results 1 to 5 of 5
Thread: Bolt Vox - Faulty HDMI or PS?
    Jul 2019
    3
    Default Bolt Vox - Faulty HDMI or PS?
    I have a one year old Bolt Vox (lifetime sub), and it appears to have died. Previously I was seeing a white pixeled screen followed by a green screen, then a blank screen. Assuming it was the HDD, I ordered a new one from Weaknees and swapped it out last night. Unfortunately that did not fix the issue.
    When I plug it in (with the new HDD in place), I one of two variations:
    * White static screen, TiVo screen, green SOD, blank screen, green screen for slightly longer, blank screen
    * White static screen, green screen, blank screen
    In both cases, the front display shows the green solid light after it is on the final blank screen. If I press TiVo or Guide I see the yellow light but there is no video output. At this point i don't know if it is the HDMI, the Board, or other.
    Thoughts?
    6,878
    Sounds to me like a bad HDMI port. Do you have any other TiVo devices on your network, or do you use the TiVo app on iOS or Android?
    Jul 2019
    3
    Yep, I have the TiVo app on iOS. I did speak with TiVo and they offered to send me a new box (obviously I will have to put the OG HDD back in it before returning it). But I am curious what to look for in the iOS App to debug.
    6,878
    Well, can you see and transfer shows in the app, when the unit is powered up?
    Jul 2019
    3
    Will check when I get home, but I will need to swap the old HDD back in first since I don't even know if the knew one got anything written to it.
