Results 1 to 4 of 4
Thread: TIVO BOLT VOX will not pair
  1. #1
    Join Date
    Aug 2019
    Location
    Ohio
    Posts
    2
    Default TIVO BOLT VOX will not pair
    I have a TIVO BOLT VOX 500GB unit. Recently the unit dropped its pairing with the remote. While in RF mode I can use the VOX button and it will do what I ask. But all other buttons will not affect the TIVO. The only fix I found was to set the controller to us IR only. I purchased a new remote, mainly to see if new remote would pair. OH, and yes I replaced batteries. I'm not sure if I might have an RF antenna issue, or maybe something more serious happening. Anyone run into this issue, and may have solution for it?
  2. #2
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,879
    Default
    Pretty strange - have you tried a Global Reset?
    https://www.weaknees.com/tv
  3. #3
    Join Date
    Aug 2019
    Location
    Ohio
    Posts
    2
    Default
    Yup, global, tivo button+back, tivo+live, 221 code, etc. Spoke with tivo support, they just had me set to IR mode.
  4. #4
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,879
    Default
    I can't say I've seen it before, but it sounds like the antenna in your TiVo is failing, if both remotes produce the same behavior.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
