Why aren't my Season Passes recording?!?
This is a sticky topic.
    Yes, I got recordings, wrong recordings. I did redo Guided Setup, on both units. I have tried everything I can think of, including using the troubleshooting guide. I switched cable boxes, I switched Ethernet cables, and I rebooted both units. Nothing seems to make a difference.
      Does it change channels on the cable box properly when you watch live TV?
        Yes, I changed channels 25 times randomly using the number buttons and then several channels using the channel up & down button. Changed to the correct channel every time. I really appreciate your time on this problem. I'm at my wits end.
          I just now checked out last night's recording of The Tonight Show. At 25 minutes into the recording, the DVR switched to channel 1, the On Demand menu.
          • #20
            Well, it may not be the DVR. It may be the cable box doing something random. Or it could be IR interference.
            This has never happened while you're watching live TV?
            • #21
              I never watch live TV. But I will give it a try. I even record the news. I bought my first Tivo the same year they first became available. I can't live without it. I now have 4. One is not working, I need to send it in to you guys to fix it. The one in the bedroom is working fine, cable box & all. It is only the two in the living room that I am having this problem. The strange thing is that, up until 2 weeks ago, they were working fine, then suddenly, one Tivo started acting up, and a week later, the second one started.
              The thing that is so puzzling, it is happening on two DVR's & both cable boxes. I have switched the cable boxes and it still happens on both DVR's.
              If the problem is IR interference, how can I find out if that is the problem?
              • #22
                To rule out IR interference, move the TiVo and cable box to another TV, in another room, and see if the problem persists.
                • #23
                  Jeff, you rock! I separated the two cable boxes and haven't had any more problems. I really appreciate your help.
