WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > Other Products (DVRs, DirecTV Equipment, AppleTV, etc.) > DirecTV DVR Plus
WeaKnees TiVo Store Register FAQ Members List Search Today's Posts Mark Forums Read
DirecTV DVR Plus The HR20, HR21, HR21 Pro, and HR22 made by NDS for DirecTV. Also post here for SD DirecTV DVRs without TiVo.
Reply
Thread Tools Display Modes
  #1
Old 03-26-2010, 03:55 AM
DIGGER DIGGER is offline
Junior Member
Default Please Help, HD dvr problem
Originaly had 2LNB dish which fed a splitter in the garage which in turn fed 4 standard receivers and 1 standard DVR. Finished the basement and wanted HD so I called Directv and they cahnged the dish to 5LNB. The tech ran 2 wires directly to the HD DVR and 2 wires to the original splitter. Now comes the problem, I changed the standard DVR to HD yesterday and ran a second wire from the splitter to it but it does not receive any HD channels. Is there something that I am doing wrong? I think I know where this is going, a swm, but the wires running to the HD DVR in the basement can't be accessed after the enter the house. Any suggestions would be greatly appreciated. Thanks
  #2
Old 03-26-2010, 04:44 AM
WK-Michael's Avatar
WK-Michael WK-Michael is offline
WeaKnees!
Default
It's just the wrong multiswitch. It's probably a 3x8, which doesn't support HD.
If you get a SWM, you can run two wires from the legacy port to your old switch, and then run one SWM wire to each HD DVR.
http://www.weaknees.com/swm
  #3
Old 03-26-2010, 05:10 AM
Junior Member
Default
Is there a multiswitch I can replace it with that will support HD and standard without havig to go to a swm?
  #4
Old 03-26-2010, 06:30 AM
WK-Jeff WK-Jeff is offline
Administrator
Default
The 6x8 is compatible with a 5lnb dish:
http://www.weaknees.com/directv-multiswitch.php
  #5
Old 03-26-2010, 06:50 AM
Junior Member
Default
Do all 4 wires need to feed it or can I get away with 2?
  #6
Old 03-26-2010, 08:00 AM
ebmsjml's Avatar
ebmsjml ebmsjml is offline
Member
Default
Quote:
you need to run all 4 lines from the dish to it ... then distribute from there...
you will have a total of 8 lines out ...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright WeaKnees.com 2006
