WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > TiVo Upgrade Center > Interactive TiVo Upgrade Instructions
Interactive TiVo Upgrade Instructions Forum for use with http://www.upgrade-instructions.com
Reply
Thread Tools Display Modes
Old 04-08-2008, 10:37 AM
calcallender calcallender is offline
Junior Member
Default Using Ghost
I was wandering why I couldn't just take the old drive out, use ghost to copy an identical image to my new drive and put the new one in. Has anyone tried this?
Old 04-08-2008, 02:08 PM
WK-Michael's Avatar
WeaKnees!
We're not sure why, but Ghost can't seem to work with drives formatted this way. We haven't tried in years, but it doesn't seem to do the same low-level copy as something like the Unix utility 'dd' does.
Old 04-09-2008, 07:50 AM
Junior Member
Default bit by bit
Doesn't ghost do a bit by bit copy? I used it for the first time about 3 months ago to copy my pc's old hard drive to the new one. When I did it through DOS it copied everything, including operating system and drivers, exactly. If no one has tried it in years, maybe I will try it first before I go through all the steps of doing it the other way.
I thought that maybe it wasn't possible because of changing hard drive sizes the new drive wouldn't register its correct size with tivo and maybe tivo would not have access to the new space.
  #4
Old 04-09-2008, 08:08 AM
WK-Michael's Avatar
WeaKnees!
Just be careful about booting into Windows with a TiVo drive connected. That'll render the drive inoperable.
Tell us how it goes.
  #5
Old 04-14-2008, 12:43 PM
Junior Member
Thanks for the tip about booting into Windows with a TiVo drive connected. I had no idea it would kill the drive. I will let you know.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright WeaKnees.com 2006
