WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > TiVo Upgrade Center > Interactive TiVo Upgrade Instructions
Interactive TiVo Upgrade Instructions Forum for use with http://www.upgrade-instructions.com
Reply
Thread Tools Display Modes
Old 04-11-2008, 08:03 PM
fordo fordo is offline
Junior Member
Default Weird Programming Issue After Upgrade
Hi,
I just replaced the hard drive on my Hughes DirecTv. Replacement went fine. But the programming data is weird. I can record, for example, The Simpsons if I record it from the Guide but it doesn't show up when I Search by Title. And when I create a Season Pass for the Simpsons, it shows zero upcoming episodes. But if I cruise thru the programming guide, I see an episode or two a day. But since it doesn't record from Season Pass, I need to record all of the Simpsons episodes by going through the Programming Guide day by day.
Is this a weird TiVo issue that they can fix for me or could this possibly be related to the fact that I just replaced the hard drive?
Please help!
Fordo
Old 04-12-2008, 07:43 AM
WK-Jeff WK-Jeff is offline
Administrator
You need to let the unit process the guide data...it can take a day or so after the drive is first installed.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright WeaKnees.com 2006
