WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > TiVo Upgrade Center > Interactive TiVo Upgrade Instructions
Interactive TiVo Upgrade Instructions Forum for use with http://www.upgrade-instructions.com
Reply
Thread Tools Display Modes
Old 05-19-2008, 05:25 AM
kennlee kennlee is offline
Junior Member
Default Can Tivo 1 use Tivo 2's old drive?
I have two Series 2 TiVo units, a 40-hour 540040 and an 80-hour 540080. Both are working fine. I would like to upgrade the 40-hour unit to the 160 GB drive ($119). That upgrade sounds easy enough. Can I then add the old 40-hour hard drive to the 80-hour TiVo? From what I've read, the power supply in the 80-hour unit can handle the extra drive without the PowerTrip device, but I don't know if the old 40 GB drive would need to be reformatted in some way before it would be recognized by the 80-hour unit. I'm not familiar with Linux, so the easiest solution would be the best solution for me. Thanks.
Old 05-19-2008, 08:06 AM
WK-Michael's Avatar
WeaKnees!
You'd need a PowerTrip:
http://www.weaknees.com/powertrip.php
and maybe a bracket:
http://www.weaknees.com/tbpta5.php
and you'd need to format the pulled drive yourself:
or have us do it:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright WeaKnees.com 2006
