WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > TiVo Upgrade Center > Interactive TiVo Upgrade Instructions
Interactive TiVo Upgrade Instructions Forum for use with http://www.upgrade-instructions.com
Reply
Thread Tools Display Modes
Old 09-25-2008, 09:24 AM
TGrim1 TGrim1 is offline
Junior Member
Default Series2 DT upgrade
can I put in a 750GB drive in this unit with MFSTools? I've upgraded drives in a DTivo R10 before so I'm assuming its the same procedure, just wondering if there is a size limit I can upgrade to on the Series2 DT.
thanks
Old 09-25-2008, 03:54 PM
WK-Michael's Avatar
WeaKnees!
No realistic limit - 750s are fine!
Old 09-26-2008, 11:09 AM
Junior Member
cool, thanks.
I know most around here prefer the Seagate db35's but are the Western Digital AV's any good?
  #4
Old 09-26-2008, 11:34 AM
WK-Michael's Avatar
WeaKnees!
Actually, yes, the AV line that WD makes is great!
  #5
Old 10-16-2008, 02:49 PM
Junior Member
My mobo only has 1 IDE, is that going to be Primary master and slave or Secondary? I guess what I mean is do I use hda and hdb or hdc and hdd when transferring from a smaller Tivo drive to a larger one?
Thanks for the help!
  #6
Old 10-16-2008, 02:58 PM
WK-Michael's Avatar
WeaKnees!
That's primary - but the tools generally won't write to HDA so that they don't accidentally overwrite your Windows drive, so make that the source drive.
  #7
Old 10-16-2008, 05:13 PM
Junior Member
Thanks Michael, I'll give it a try tonight.
  #8
Old 10-17-2008, 06:39 PM
Junior Member
worked great, thanks!
  #9
Old 10-17-2008, 09:10 PM
WK-Michael's Avatar
WeaKnees!
Glad to hear it!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright WeaKnees.com 2006
