| Interactive TiVo Upgrade Instructions Forum for use with http://www.upgrade-instructions.com |
Thread Tools | Display Modes |
I just started my upgrade today and things aren't going as smoothly as I would've liked. I'm sure its me so I'm posting for a little direction.
I am adding a 500GB HDD to my Tivo Series 2. I purchased a SATA HDD and am using a SATA - IDE bridge so the drive will work in the Tivo. To format the drive I connected to my Vista computer, assigned it a drive letter and then used a utility called fat32format to allow a FAT32 file system to be applied to this big HDD. All of my drives appear as they should in the information provided by the Weaknees utility. However when I attempt to mount the new drive with the FAT32 file system I get an error. First attempt: mount /dev/hdb1 /mnt Error: kmod: failed to exec /sbin/modprobe -s -k nls_cp437, errno = 2 Error: kmod: failed to exec /sbin/modprobe -s -k nls_iso8859-1, errno =2 The latter error repeats 2 more times. Second attempt: mount /dev/hdb /mnt FAT: bogus logical sector size 190 VFS: Can't find a valid FAT filesystem on dev 03:40 UMSDOS: msdos_read_super failed, mount aborted and then it repeats. What am I doing wrong? Also, couldn't I just use Acronis True Image Boot CD to image the Tivo drive? Thanks, MJ |
I wound up using a program called Swissknife that did an awesome (fast & efficient) job of properly formatting this drive. I think the problem was that the drive did not format properly with the first program.
Frankly I'm not sure why the first format didn't work. But I also couldn't get Windows to format the drive with the NTFS file system and the DOS command: format d: /fs:FAT32 didn't work either. I still got that short list of "kmod:failed . . ." errors when I attempted to mount the drive. Maybe they're not errors. I'm no Linux guy. But I moved on and the backup worked well. I'll post again if I run into any other trouble. MJ |
| Thread Tools | |
| Display Modes | |
