WeaKnees TiVo Forums
Go Back   WeaKnees TiVo Forums > Everything TiVo > TiVo Hardware Forum
TiVo Hardware Forum Questions, descriptions, problems . . .
Reply
Thread Tools Display Modes
Old 05-14-2007, 12:33 AM
Axel Axel is offline
Junior Member
Default Toshiba SD H400 Keeps restarting
My unit is 2 plus years old. I recently had problems with it continually restarting. It says it is scheduled for a VCM update in about 20 minutes. This time happens to coincide with another reset. When it restarts it will work marginally until the next VCM scheduled update. The menu options work slow, the audio cuts in and out and the video sometimes will momentarily freeze on live playback.
I want to verify if it sounds like a hard drive problem or a power supply problem. I'm on the road right now, so I can't verify if the DVD players functions normally during this time frame.
Thanks in advance
Axel
Old 05-14-2007, 02:13 PM
WK-Michael's Avatar
WeaKnees!
That sounds pretty much like a drive problem. If you had a bad power supply, it likely wouldn't boot at all.
Old 08-09-2007, 11:39 AM
mdellinger mdellinger is offline
Junior Member
I'm having this same issue, been using the Weaknees CD to go from an old hard drive to a new one. And now it seems that with either hard drive the unit starts up for about a minute and then restarts itself.
  #4
Old 08-09-2007, 11:43 AM
WK-Jason's Avatar
WK-Jason WK-Jason is offline
WeaKnees!
Quote:
Not sure which CD you're referring to, but if you're taking the software from the old drive and loading it on the new one, sounds like you may have inadvertently transfered over some software corruption.
__________________
  #5
Old 08-09-2007, 11:50 AM
Junior Member
I tried imaging the hard drive without saving the recordings to minimize any issues that may have come later. Is there any way for me to fix the corrupted software? Or is the only option another image?
  #6
Old 08-09-2007, 12:51 PM
WK-Jason's Avatar
WeaKnees!
No way to repair the corruption, I'm afraid. You'll probably need to use an entirely new image.
__________________
  #7
Old 08-12-2007, 04:42 PM
Junior Member
Is there any place I can get a new image from? I had tried using InstantCake, but was having trouble using the USB port for connecting through the network, and it looked like the Tivo Basic would no longer be available.
It seems that the restarting corresponds with accessing recorded video on the hard drive (The Now Playing area, Live TV, the Todo List). I've already gone through and reset the settings and that didn't seem to help
  #8
Old 08-13-2007, 06:35 AM
WK-Michael's Avatar
WeaKnees!
We can reformat a known-working drive for you with the correct image. More info is here.
  #9
Old 08-14-2007, 04:47 PM
cma371 cma371 is offline
Junior Member
I need a backup image file for my SD-H400, my hard drive crashed. Can I get a copy from anyone
  #10
Old 08-14-2007, 06:26 PM
WK-Michael's Avatar
WeaKnees!
See the link above - you can send us the drive and we can reformat it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright WeaKnees.com 2006
