Think your tivo hard drive is dead? Here's how to find out...
This is a sticky topic.
Green screen is typically caused by a failed hard drive; I'd start there.
Whether you can put your drive into an external case depends on whether the testing software will recognize drives attached to a USB port. You'd have to look at the testing software to see. BEWARE of attaching your drive while in Windows XP. You have to get a DOS-based version of the testing s/w, which may not like a USB-attached drive.
Leave a comment:
I plugged in my Tivo Series 2 after a year or so of it not being used. Everything worked ok for a couple days and then it started overheating and switching itself off. I noticed the back fan wasn't spinning so I replaced that. It worked fine for another couple of days and then it did the GSOD but after 30 minutes or so it started back up again and worked for about a day. The all of a sudden while I was watching TV it shut itself off kind of suddenly, and when rebooting it hangs at the Please Wait screen. Any idea whether this is a HD or power supply issue? How can I tell the difference? I am thinking of pulling out the HD to run diagnostics but if you guys have a different idea let me know. Thanks. Also, a side question -can I plug the HD into an external IDE USB enclosure to run diagnostics that way? Thanks again. Hoping for a quick response as I have some time to troubleshoot tonight. Awesome site!Last edited by n8mack33; 05-13-2010, 03:56 PM.
Leave a comment:
Originally posted by Killerpcs View PostI have a hughes HDVR2, its powering up, cycling through the Welcome, and almost there screens and then reboots. I tried following the directions to test the drive in the tivo but could never get to the test screens. I took the drive out, ran it through maxtor powermax testing and it reports the drive is fine. Is my best bet to buy a replacement drive, or is there anything else that could be causing the issue?
thanks,
Dave
Leave a comment:
HDVR2 constant reboots
thanks,
Dave
Leave a comment:
We have a TiVo Series 3 that stopped working.. it would respond slowly at first and then finally stopped doing anything. Having replaced a hard drive in a Series 2 a few years ago I assumed this was the problem. Sorry to say.. I flipped a coin and ordered a hard drive from a competitor of yours. When I installed the new drive and plugged it in.. I get four colored lights on the front and the TIVO emblem lit up.. Nothing on TV screen. I checked installation and tried again.. same result. I did an online search for help and was directed to your trouble shooting page.. It was suggested that even though the fan was spinning perhaps it was the power supply... I ordered the needed unit from you and installed it this afternoon. With the TIVO on the kitchen table and the case open I plugged it in... the same four colored lights..I had earlier tried this with the cablecards removed.. made no difference. I am at a loss.. have more invested in this repair so far.. $2.13 just for a T8 torx bit.. added to the large hard drive and the power supply than the cost of a new Premier model TIVO.. Any help greatly appreciated
Leave a comment:
Bah, I read that the first time I visited! Early onset senility, coming to a town near you! Thanks again, I'm off to play Sherlock Holmes for a while...
Leave a comment:
Originally posted by FubarGuy View PostGot the unit open, I think the drive that's in there is the original. It's a WD800BB 80GB model, so I bet it's just toast. Are there any diagnostics I can run by hooking it up to a PC, or should I just throw in the towel? I know I could get a pre-configured drive or bare drive & InstantCake it, just not sure it's worth the investment at this stage.
Leave a comment:
Leave a comment:
Wow, fast Reply! Will do, I'll report back either way. Thanks again.
Leave a comment:
Originally posted by FubarGuy View PostHey guys, not sure if this is common or not but I've got a Humax DRT400 that seems to be - unhappy. I don't use the unit very often after switching to a S3 HD model, so when I turned on the TV with the Humax recently all I saw was a single image frame from the local news, as if it was Paused. I Powered it down via un-plug method and now it hangs up at the "Welcome! Powering Up..." screen.
I've attempted to run the Code 54, 57 & 58 kickstarts. Every time, after the red light appears, I enter a Code, the screen flashes grey, then "Welcome! Powering Up…" re-appears. The left orange light stays lit for a few seconds then goes out. I've let it sit for up to 40 minutes but the screen never changes.
Guessing at this point the HD may be dead, it's an upgraded model although I can't recall the capacity, model or when I installed it, honestly. I may crack it open tonight & take a look. Any hope of reviving the unit?
I may also have the original HD, perhaps I can swap it out & see if it still functions. Thanks!
Leave a comment:
Frozen Humax
Leave a comment:
Originally posted by 1godking View PostFirst of all i would like to say hello my name is Erica
and thanks for your help.
Now I have a tivo series 3 connect to my lcd tv via hdmi and it makes a static/chirp
sound through the audio almost like a high pitch static almost like when the picture pix elates but just the sound not the picture .
I have a separate tivo 3 that i hooked up to isolate the problem and it works fine
I have tried
different hdmi cable
Dolby to pcm
restarting
unplugging
lcd tv audio settings etc
i would assume it is a hardware issue but where to I start
has any one had this problem of course I am out of warranty any help appreciated thanks .
Leave a comment:
Leave a comment:
