Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Tivo Bolt Plus with the Flashing Lights of Death
  1. #21
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,880
    Default
    That's likely to be a bad hard drive. We have replacements for that here:
    https://www.weaknees.com/bolt.php
  2. #22
    Join Date
    Jul 2007
    Posts
    1
    Default
    I woke up yesterday to the death flash. So it sounds like I need a new HD.
    Quote Originally Posted by WK-Michael View Post
    Only the 3 TB will work in a Bolt Plus.
    Does this mean strictly the 3TB, or the 3TB and the larger options listed?
    For the >3TB options, it says it requires installation by you... is that only to keep the existing drive contents? Is it possible to order a fresh clean setup for self-install in one of the >3TB sizes?
  3. #23
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,880
    Default
    We've recently learned that smaller drives are OK in the Bolt Plus and Bolt VOX 3TB. See this page:
    https://www.weaknees.com/bolx.php
    Next, we don't recommend any internal drives larger than 3TB because those drives just aren't suitable for TiVos and don't work reliably. Maybe one will come one day, but the current options show early faliures.
    For any external, yes, your unit has to come here for installation by us.
  4. #24
    Join Date
    Dec 2019
    Posts
    1
    Default
    Hi. Same problem here.
    Are the FLOD only up when there’s a boot failure?
    Can I take this drive and recover the tivo files elsewhere?
    Which is a better option? Repair the bolt+ or purchase your roamio 3TB instead?
    Neither will see tivo desktop, but the windows pc saw the old bolt+ and sees my Roamio.
  5. #25
    Join Date
    Nov 2006
    Location
    Los Angeles, CA
    Posts
    6,880
    Default
    Quote Originally Posted by Vinylm View Post
    Well, the Bolt is faster than the Roamio and has 4K support, etc. If you have lifetime service on it, it's worth fixing. And it might be worth fixing even if you don't.
    But the Roamio does use the desktop-sized 3.5" drives, and those do seem to last longer than laptop-sized 2.5" drives.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
