cable co. changed channels
  • cable co. changed channels
    About a month ago, my cable company decided to change some of the channels around (ie: CBS network channel used to be channel 9, now it's channel 2-which used to be QVC, and channel 9 is now a religious channel. So my TiVo doesnt seem to KNOW of this change... what can I do? I thought it would reset itself with the new line up info with the nightly connections it makes...? any ideas??? thanks!
    You're right - usually it figures this out automatically.
    Try re-doing Guided Setup. It should figure out that you have a different lineup.
    If that doesn't work, you'd need to call TiVo to notify them of the change.
      WK-Micheal...thank you!! I am not good with the techno stuff but felt it should have just automatically done it on it's own! I will take your suggestion and try re-doing the guided set-up.... I HOPE I dont have to call TiVo!! I've done that before and it is my worst nightmare! Impossible to get thru and resolve issues in my experience!
        They get this call often enough - if you explain that the cable company changed your channel lineup, they should be able to help pretty efficiently.
