Are you sure DirecTV has locals turned on for you?
You might need to wait a bit for the servers to send the authorization signal to the unit.
signal problem HR24-100
Local channels
Hey guys thanks again for the help,I have the sattellite dish sett up at the lease and it is working,but I cant get my local channels.
101
110
119
99c
all appear to be good and 103 california. any suggestions
Leave a comment:
Originally posted by WK-Michael View PostI really do think it's an aiming issue. These are not very forgiving in that department.
Leave a comment:
Leave a comment:
Originally posted by ebmsjml View Postgeneral direction dont work ... it has to be pointed directly at the sat ...then fine tuned...
check & verify the settings ... be sure that the settings are for the 5lnb dish ...not the older 3lnb dish for your zipcode
be certain that the pole is plumb ... & good line of site.. no blockages... with all the settings correct .. point dish too far to the west ,Then slowly move to the south .... you should cross the path of the 101 sat... then just fine tune it in...
Leave a comment:
Originally posted by john m baker View PostWell the new dish is pointed the same direction as the installed dish, when the reciever reboots ans switches to the new dish if it is in the general area of the birds shouldnt some of the trasponders pic up something?
Leave a comment:
Leave a comment:
I don't know that meter specifically, but their website doesn't talk about SWM as far as I can find. I think you're getting an incorrect reading there.
Leave a comment:
The sat finder is a DMS International freq 950-2150mhz
poer DC 13-18V. It does not say it is specifically for swm but after getting the audible tone and a reading of 10,I have tried it with the sat finder in line and without,but still the reciever does not find the satellite. I thought by pushing the red reset and unplugging the reciever it would reboot and find the signal,but so far no luck.
Leave a comment:
The run is approx 50 ft,and the satellite finder does not tell me which satellites just that it is a strong signal, when I press reset,I noticed that the reciever saves the information that was on the reciever. It still has the 77539 zipcode the dvr list remains intact. when the reciever reboots it changes to the new dish,but all transponders say 0.
Leave a comment:
How long is the run to the receiver?
Did the SAT finder see all five satellites?
Leave a comment:
Hello I recently purchased a 5-lnb-s swm satellite for the deer camp,I am having trouble getting a satellite signal to the HR24-100 box,error code 771A.
I set the satellite up in the yard on the provided tripod,used a satellite finder to get the signal,I have rebooted the reciever,unplugged the reciever,taken the card out of the reciever,still when it is connected thru the provided P121R-01 power supply I get searching for satellite,error code 771A. zeros on all transponders. Can you help me please.....
18 slimline 5s
01 SWM
tuners dual
Dish 5-LNB-S
Azim 187
Elev 55
Tilt 80Tags: None
Leave a comment:
