I'm getting an error message.
  • I'm getting an error message.
    I am trying to simply bless a new hard drive to a current one. The system is seeing the 750 GB drive I am adding as well as the current TiVo master unit. Both are being reported correctly.
    When I do the instruction:
    mfsadd -r 4 -x /dev/hda /dev/hdb
    I get the message:
    hdb: drive not ready for command
    hdb: status error: status=0x00 {}
    ide0: reset: success
    Eventually, I get these messages:
    /dev/hdb: Input/output error
    /dev/hdb3: Illegal seek
    mfs_load_volume_header: Total sectors (1463793664) mismatch with volume header (-13660497920)
    mfs_load_volume_header: Loading anyway.
    mfs_load_zone_map: Primary zone map corrupt, loading backup.
    mfs_load_zone_map: Secondary zone map corrupt, giving up.
    mfs_load_zone_map: Zone map checksum error!
    Unable to open MFS drives.
    I have checked and re-checked and I am certain I have the master and slave identified correctly. The new hard drive came straight out of the box. So, I can't imagine it's dead on arrival.
    Any ideas about how to fix this?
    Your drive is not being seen by the PC. Have you tried scrolling up (shift-page up) to see whether it is actually being seen at hdb?
    You might also try:
    hdparm -I /dev/hdb
      After doing some testing on the drive, it appears that they just sent me a dead one. Its S.M.A.R.T. status is bad.
