Originally posted by NJDave
View Post
This is a sticky topic.
I have gone past the steps noted in this thread - replaced the hard drive and removed the cable cards. When I plugin the unit to power only, I get only a blinking Blue light (and flashing on the TV screen). Help - what does this mean?
Leave a comment:
GREAT thread, I have the same issue
I came home to find my TiVo Rebooting consistently. Having replaced Hard Drives in my TiVo's before I ordered a new hard drive from Weeknees only to find the same repeating boot problem. So I pulled both multistream Cable Cards and was able to do guided set up with the new drive. Then I put in the old drive and could get to my recordings (even though the TiVo didn't like that I had pulled the Cable Cards and wanted to repeat guided set-up). However, every time I just inserted either of the two cards the TiVo immediately rebooted. I tried one last effort and that was to unplug the fan and see if the fan was drawing too much current and I got the same results. I see no physical damage to the power supply (or anything else in the box), so I was reluctant to order a Power Supply, but after reading this thread, I am going to order the Power Supply replacement from Weeknees and see if it fixes my issue as well.Originally posted by darklyte View PostLooping back to confirm that you were correct and that it was a bad power supply.
I replaced it today and the unit is back to working normally.
Again, thank you both for this thread.... extremely helpful...
Dave
PS, I will post a result in a week or so when I can get the new power supply in the unit.
Leave a comment:
Leave a comment:
thank you very much for your quick response. I'm going to try and replace the power supply and keep my fingers crossed that does the trick.
Your tips at the beginning of this thread have been critical in me getting the unit to at least work with one cable card. I really appreciate it.
I will add that as a Time Warner Cable in NYC customer, I have to use a tuning adapter. In order to get to the point where my S3 would work at all I had to follow you instructions including guided setup with nothing attached/plugged in, then next attaching the tuning adapter and redoing guided setup a second time before putting in the cable card.Last edited by darklyte; 12-04-2015, 03:32 PM.
Leave a comment:
Thank you very much for the quick response, I really appreciate it.Originally posted by WK-Michael View Post
I'll try a different power supply and keep my fingers crossed that it fixes the issues!
Leave a comment:
Leave a comment:
I need some help desperately as my TiVo recently started encountering these problems as generally described in this thread.
I have a Tivo Series 3 HD unit with an upgraded WD green 1TB HD, two cable cards one single and the other multi-stream.
Connected via HDMI out to TV, coax in for signal, cable tuner via usb, and ethernet cable.
I woke up to find my TiVo in a reboot cycle.
After some trial and error, I found that the TiVo would start fine when the cable cards are removed. I followed the instructions on this thread and repeated guided setup, then was able to use the TiVo and access my recorded shows no problem. This makes me think it is not a failing HD.
I found that every time the multi-stream card was inserted regardless of which slot, the TiVo would shut down and go into the reboot cycle. But the single stream did not seem to cause it to reboot, it would say a cable card is now inserted...
After repeating guided set-up I inserted and got the single stream cable card set up and working 100%. It worked fine and was receiving shows after getting the cable company to ping the card.
Next step, I got a new card from the cable company in case the old multi-stream card went bad. I inserted the new cable card, a multi-stream, into card slot 2 and TiVo automatically shuts itself down and goes into the reboot cycle again.
So I pulled that card and went back to using just the single-stream in slot 1 on the TiVo.
The TiVo NOW goes into the reboot cycle with the single-stream which previously worked. I'm currently repeating guided set-up to see if the original single stream card will work again.
In all this, I can continuously get TiVo to start fine and view my recorded programs as long as no cable card is inserted.
Based upon some other things I've read I thought it could be a bad power supply. I opened up the unit and do not see any obvious signs of bad capacitors but know it still could be bad.
Does anyone have any suggestions for getting things back up and running normally and what sounds like the cause?
Leave a comment:
Thanks for the help so far, I tried the kickstart 54 last night, the S.M.A.R.T. tests all seem to pass tivo kickstart 54 test results.jpg
after a power cycle, my unit froze at tivo central, but it was blank...tivo after kickstart reboot.jpg
I cycled power again and it came back up but later this morning my wife said that "live tv" was a blank gray screen with no audio.
i asked her to cycle power again but i haven't heard the results, so i'm not sure where to go now.
Leave a comment:
Sounds like one or both of the drives are failing. I'd do a kickstart 54 to check them:
http://www.weaknees.com/54
Leave a comment:
I have an HD (series 3?) that was new in Jan. 2011, has been used with a WD "My DVR Extender" (500Gb) since new. No CableCards, always OTA. Last night it rebooted by it self twice, once while watching live TV and the second during the first reboot, after the second screen (Almost there...). When it finally came back to life, i pressed the "Live TV" button and saw a "blue screen with a swirly circle" saying something like "Acquiring channel data" so i went to bed hoping it might finish. I woke up a few hours later and it never went away, so I rebooted again. When it came back up everything was fine.
I saw the "blue screen with a swirly circle" once before this summer and rebooting fixed the problem. Also earlier this summer i have noticed that a couple of the programs that were recorded did not have any audio, however others from that same day did and Live TV did. I'm wondering what this could be.
Leave a comment:
I'd suggest you start by taking a look at the power supply. For more information, see:
TiVo Power Supply Problems--What to look for
Leave a comment:
My Series 3 has never had a problem until it started rebooting continuously about a week ago. I had bought a drive upgrade last year from WK and immediately installed it thinking it was a drive problem. Not so. Continues to reboot continuously. Never gets beyond initial "Please Wait..." screen. I've tried all suggestions listed. Nothing changes. Can't get it to do a "kickstart" either.
Should I send it in for repair? Or do I give up and build a computer DVR?
I have Verizon Fios and also have digital antennas that I don't use. I've tried every configuration I can imagine. Unhooking this and that and then replacing them. Nothing stops or even affects the continuous rebooting.
I LOVE TiVo and have had one since they were first introduced. Upgraded every time there was a new model until Series 3. I consider it perfect, but I won't ever buy another TiVo because although I've transferred my lifetime several times I consider current transfer rates totally unreasonable.
Leave a comment:
Leave a comment:
